 Help...pyesa sa trial?
illateast
Lurker
Lurker
Number of posts : 35
I ride a : Stock/Mod
Registration date : 2009-03-17
PostSubject: Help...pyesa sa trial?   Tue Mar 30, 2010 4:38 pm
Good n mejo mura pyesa...for mod...T master un frame ko mga sir...
1. cranks
2. bottom bracket
3. rear tire (for 20" rim)
4. Vbrakes
5. rear hub
6. freewheel
7. headset
8. brake cable
9. brake pads
Mga sir pwede malaman un specs n rin...how much it would cost?
davidoff
Number of posts : 1153
Bike : Street Preachers, Onza T-Master
Registration date : 2008-03-04
PostSubject: Re: Help...pyesa sa trial?   Tue Mar 30, 2010 5:37 pm
ey illateast! ikaw ha, ang tagal na ng frame mo ngayon mo nalang ulit piunansin, pero ok nadin...
Davidoff nga pala, tmaster user din.
ang masusuggest ko ay ayon sa set up ko... na for me, ok na ok nadin.
1. cranks: kahit na anong 165mm 22t, sakin truv hussefelt
2. bottom bracket: magdedepende sa cranks mo.
3. rear tire (for 20" rim): hanap ka ng maxxis max daddy na 2.3 P650
4. Vbrakes: avid SD5 set, black900 gray1200
5. rear hub: any threaded,seald bearing,14mm hub: 800ata
6. freewheel: shimano DX 16t P550, sakin suntour 16t P95
7. headset: any sealed. 700-900, sakin cane creek s2
8. brake cable: MOB pwede na P70
9. brake pads: MOB P100, world cat clear ask tzard, pero may clear din sa flipbykes P450
illateast
Lurker
Lurker
PostSubject: Re: Help...pyesa sa trial?   Tue Mar 30, 2010 6:24 pm
mgkano truv hussefelt crank sir?ano compatible bb d2?mgkano sir?
illateast
Lurker
Lurker
PostSubject: Re: Help...pyesa sa trial?   Tue Mar 30, 2010 6:39 pm
@davidoff - tnks sa suggestions...nahati kc kaisipan ko s bmx street...tpos npansin ko un trial ko n malungkot kaya naisipan ko subukan un trial kaso kulang un pyesa...
illateast
Lurker
Lurker
PostSubject: Re: Help...pyesa sa trial?   Tue Mar 30, 2010 6:44 pm
Tnk u pla sa suggestions @davidoff...oo nga mtagal n un frame ko sir ...2004 p yata...gusto ko itry un trial...kaso dko masyado alm un mga pyesa...
davidoff
PostSubject: Re: Help...pyesa sa trial?   Wed Mar 31, 2010 7:51 am
medyo mahirap nadaw ata makahanap ng 165 na brand new, pero check mo padin.
baka nasa mga 3k ata ito. ang sakin nakuha ko lang na 2nd hand 1.5k.
ang BB nito ay truvative giga pipe isis.
kung wala na talaga, siguro pwede na pansamantala ang 170mm cranks...
illateast
Lurker
Lurker
PostSubject: Re: Help...pyesa sa trial?   Sun Apr 04, 2010 1:14 pm
Available b s quiapo mga yan sir?tnx...un brake booster pla...kelangan b tlga un?magkano pla chain tensioner?ano ok n brand?
Abe
Sport
Sport
Number of posts : 146
Bike : Onza T-master
Registration date : 2009-05-21
PostSubject: Re: Help...pyesa sa trial?   Tue Apr 06, 2010 12:27 pm
Bro eto specs nung sa akin, eto na siguro lowest na setup
1. cranks-generic 170mm P750 (matibay to as in tatlong bikes na ang sinerbisyuhan nito, pang-apat tong Onza) pero mas advisable yung 165mm kung makakahanap ka
2. bottom bracket- shimano 110mm P450 (pero mas advisable yung 115 to 117 para di sumayad yung chain sa bashguard)
3. rear tire (for 19" rim) - 19x2.50 Creepy crawler P500 (for 20"-pwede yung 20x2.25 or wider na Mxxis Max Daddy - P570)
4. Vbrakes set including lever - Avid SD7 P1200
5. rear hub - 14mm cassette-type P850
6. 16teeth spline cog - P1000 (pag bumili ka ng 9-to-1 Dabomd SS converter kit, may kasama tong 18 at 16 cog, plus spacers and lock) or pwede rin yung 16t SS Surly cog - P850 sa Ross bikeshop, P1050 sa Bikezella sa Ortigas)
7. headset - FSA ball bearing P550
8. brake cable - GW - P70 or MOB (P35 each)
9. brake pads - MOB -P160 (P80 each)
10. pedal - Wellgo plastic pedal - P450
11. front hub - generic - P130
12. front tire - Hyper by Leo tires - P105
13. Stem - Titec 150mmx30degrees - P300
14. Handle bar - Answer protaper - P1100
15. Chain - KMC K710 - P350
16. tensioner - Haro - P250 (P125 each)
17. tubes - Heavy duty tractor tube - P120 (P60 each)
18. spokes - generic stainless spokes - P260 (P130 set)
19. Grips - Sars lock-on grips - P250
20. Fork spaces - generic aluminum spacers - P200 (P40 each x 5 pcs)
21. Brake booster - P150
22. 19" rim - P350
23. 20" rim - generic - P280 (OK pa naman hanggang ngayon)
illateast
Lurker
Lurker
PostSubject: Re: Help...pyesa sa trial?   Tue Apr 06, 2010 1:47 pm
@Abe...tnk u s suggestions...very helpful guide...prang ngpaquote n din ko ng MOD setup...libre p...hehe...tnx...
joolz
Macho Dancer
Macho Dancer
Number of posts : 612
Bike : wala sa ngayon
I ride a : kalas si jeproxx
PostSubject: Re: Help...pyesa sa trial?   Wed Apr 07, 2010 11:55 pm
abe san ka nakabili ng titec stem na 150mm? ayus solve ako kapag nakakita ako neto!!!
WTF?! I can't trackstand!?!?!?!
Abe
Sport
Sport
PostSubject: Re: Help...pyesa sa trial?   Thu Apr 08, 2010 10:03 pm
Ay mali pala, 120mm lang pala to. Excited kasi sa order kong Bionic eh.
» Kenteris/Thanou Trial: Making sense of the nonsensical
» 2-up Time Trial Royal Navy Royal Marines Cycling Association
» trial 39 @ windrock
» 30 minute trial of Kiko Reel Keel today
» The Marines Murder Trial
pinoytrials :: Bike Trials :: Beginners Area-
