 lever saver
lord vader
Number of posts : 406
I ride a : bike with no seat
Registration date : 2008-08-28
PostSubject: lever saver   Sat Sep 05, 2009 9:51 am
sa mga nagaaral na magsidehop (like me) higher than the bars, this migth be helpful to save the lever if it would hit a ledge.
i made it out of a broken MTB lever
@jay18 gawa din ikaw nito hehehe
hope this helps
for the front disc protector i`m still figuring it out hehehe
or may nabibili ba nun?
erikjon
Beginner
Beginner
Number of posts : 88
Bike : Old skool
I ride a : Basta...ols skool sya...really old.
Registration date : 2008-12-04
PostSubject: Re: lever saver   Mon Sep 07, 2009 9:03 am
Sir Oca, may front disc protector pero plastic lang sya. i'll find a picture and sned it to you. not sure how you can get it to work for you, siguro make a metal one yourself, pero at least may option ka.
lord vader
PostSubject: Re: lever saver   Mon Sep 07, 2009 9:19 am
thanks sir erikjon!
eto pinaltan ko, nahingi ko lang yung lever sa LBS
looks a lot better ang lighter!
all i need to do now is sidehop a ledge higher than my bars! nanaykupo! wahaha!
PostSubject: Re: lever saver   Mon Sep 07, 2009 9:59 am
Ok yan pre, mukhang seryosong ensayo na ito
davidoff
Number of posts : 1153
Bike : Street Preachers, Onza T-Master
Registration date : 2008-03-04
PostSubject: Re: lever saver   Mon Sep 07, 2009 10:04 am
career-an! good thinking oca!
nabash ko nga din lastweek yung rotor ko. nagulat din ako di naman bumingkong,
matibay tiba din pala yun...
lord vader
PostSubject: Re: lever saver   Mon Sep 07, 2009 4:11 pm
improvising out of necessity ika nga, nyahaha!
nakaka-sidehop na kasi ako nga waist high (from backhops yun ha, yabang ko! sana tumaas pa wehehe)
i remembered quite well ang nangyari kay jay18 at dun sa lever na nakita ko sa HK, ganun din ang pagkasira, tumama sa ledge
sana maglabas sila ng commercial lever saver at disc saver
or manghingi na lang ng itatapon nang lever sa LBS!
JANG
Number of posts : 1484
Registration date : 2009-03-09
PostSubject: Re: lever saver   Mon Sep 07, 2009 9:39 pm
ako isang ruler palang ata taas, paside na backhop ginagawa ko... sana tumaas pa
Ocs galing nyan ah! +1 sayo!
lord vader
PostSubject: Re: lever saver   Tue Sep 08, 2009 9:02 am
thanks senyo!!!
ewik
Number of posts : 325
I ride a : Dirt/Street Two50
PostSubject: Re: lever saver   Tue Sep 08, 2009 8:45 pm
ewan ko kung ubra yung di masyado mahigpit na lever... yung pag na-bash dun lang sya gagalaw.
save weight, ride hard
lord vader
PostSubject: Re: lever saver   Wed Sep 09, 2009 11:03 am
ser nasubukan ko na yun, pero ibinalik ko na uli sa mahigpit.
as we all know trials are very brake dependent, very stressed ang lever components.
problem is, too much stress on the lever and bar clamps (w/c should be not too tight as you suggested, but just enough) will eventually get loose (or move a bit) during repeated use, and because of the stress, may tend to break or crack the lever and bar clamps during repeated use.
sa mga motor ko nagawa kona din yan, ganun din results, eventually lumuluwag.
minsan muntik na matanggal ang clutch lever ko kasi sumobra luwag hehehe
now i use bark buster or lever protectors, but delikado pag sumout ang braso mo doon pag semplang, `happened to one of my riding buddies, nabali braso.
anyway thats a different story.
just my 2 cents
zteg43
Number of posts : 3067
Bike : echolite 07
Registration date : 2008-03-30
PostSubject: Re: lever saver   Mon Sep 14, 2009 12:10 am
actually yun ang iniisip ko. pag nabash yung protector at syang umipit sa kamay mo... nanay ko po! pakanan pa naman side hop ko!!! good bye career ako pag ganun....
View user profile http://www.dyanilaotattoos.multiply.com
lever saver
» Lever Action Airsoft Rifle
» EMP Tranny Saver
» Lure Saver....Does what it says on the tin!
» My rod saver
» Will Hydraulic brakes from ATVs and pit bikes work on a tractor?
pinoytrials :: Bike Trials :: Bike Trials Talk-
