 FFW problem
Go to page : 1, 2  Next
benjo
Number of posts : 993
Bike : Zhi z3r
Registration date : 2008-02-29
PostSubject: FFW problem   Thu Sep 03, 2009 10:09 pm
Tried removing my cranks again with a realy quality crank removing tool from cycle opts... (park tools)
like magic, it got off!! coolman almost everyone thought it was imposible... hehehe...
Was excited the whole day to install my new ZHI cranks and my Neon bashring thats been sitting in my cabinet for a few months now...
I didnt know i still have a problem... the ffw wouldnt come off... F*%k!!
almost everything i do wouldnt really work!!
tried using a quality wrench and a combination of 4ft heavy metal for leverage, but my wrench broke into pieces!!
that didnt work, so i tried using a cross wrench, the one you use for removing tire knots and still the combo of the long metal for leverage...
it didnt work either... Puta!!
I guess thats the only "major problem" for using a FFW or should i say the usual FW... "Removing it"...
Only solution now is to get a new FW...
I actually was planning to get a new one, but not at the moment...
Being so excited the whole day, i just installed the old crank set again and just biked around...
Hope you've learned something here... or if you have anymore solutions, just let me know...
heres a pic...
davidoff
Number of posts : 1153
Bike : Street Preachers, Onza T-Master
Registration date : 2008-03-04
PostSubject: Re: FFW problem   Thu Sep 03, 2009 11:10 pm
grabe yan benjo ah! namumutol. at 4' leverage? di padin bumigay?
sabihin ko sana i soak mo sa wd40 kaso baka masira naman ang original lubrication nun FW...
try mo hanap ng malaking bench vise (gato), tsaka mo uli birahin Very Happy
stupid suggestion: check threading baka kontra hehehe
Number of posts : 2951
Bike : Adamant A2 / GT Chucker
Registration date : 2008-02-26
PostSubject: Re: FFW problem   Thu Sep 03, 2009 11:14 pm
Did you try lubricants? Like WD40? It helps in removing tight bonding rusty metals. It might help. Just spray a little on the contact points.
apol
Number of posts : 453
Bike : Sinister WTF/ Giant STP/Giant Reign X/Giant Trance X
I ride a : stock/ dj4x /Freeride /XC
Registration date : 2008-03-05
PostSubject: Re: FFW problem   Fri Sep 04, 2009 12:26 am
+ 1 ung gato, and if you can use a close wrench mas ok kasi iwas cabyos.
JANG
Number of posts : 1484
Registration date : 2009-03-09
PostSubject: Re: FFW problem   Fri Sep 04, 2009 2:52 am
try mo un ginawa ni oca, nagkekwentuhan kami nun sa pickup nya, ang sabi nya ginamitan nya ng crosswrench ng gulong nya, inipit at "TSAHDAN" tanggal!
yan ay ayon sa natatandaan ko sa sinabi ni oca...
OT: benjo, anong balak mo sa lumang bashring mo? hmmmmm... hehehehehe
benjo
Bike : Zhi z3r
PostSubject: Re: FFW problem   Sat Sep 05, 2009 3:13 pm
potek ginawa ko na yan lahat, xcept yung ibabad nga sa wd40 hehe, hindi nga pwede yun david...
lord vader
Number of posts : 406
I ride a : bike with no seat
Registration date : 2008-08-28
PostSubject: Re: FFW problem   Sat Sep 05, 2009 4:52 pm
benjo ganito gawin mo, bili ka ng nut & bolt na mahaba(yung lampasan pag tinuhog mo ang tool,sprocket at crank), tsaka apat na washer para dun sa bolt.
tapos ung ulo ng bolt lagyan mo 2 ng washer, isout mu doon sa sprocket tool, tapos isuot mu sa butas ng crank at ffw, itama ang notches ng tool sa sprocket, paglampas nun ilagay mu washer tapos yung nut. higpitan ng konte.
eto ay para di kumalas ang tool sa ffw, nakasecure sya.
then ikalang mu ang crank (with pedals para di luminsad sa gulong) sa anything na matigas, saken sa gulong ng pickup ko ikinalang, then pihitin mu ng wrench using a longer tube for leverage. kita mu syonggal agad yang lola mo. hehehe
hope this helps
lord vader
PostSubject: Re: FFW problem   Sat Sep 05, 2009 4:59 pm
parang ganito
di kelangan mahigpit, just enough to hold them together at di kumabyos ang tool.
tapos nga ikalang ang crank w/ pedals sa goma ng oto, then pihitin ng wrench ang tool using a longer tube for leverage.
bale 3 point leverage ito, sa goma, sa sahig (na nakakalang ang bashring) ,lastly ang wrench
hope this helps benjo
lord vader
PostSubject: Re: FFW problem   Sat Sep 05, 2009 5:11 pm
hindi crosswrench, katala po nigamit ko
jang akala ko kunin mo bashring at BB na kasama ng echo cranks mo?
lord vader
PostSubject: Re: FFW problem   Sat Sep 05, 2009 5:16 pm
ni-try kona din babadan ng ice hoping to shrink a bit yung metal ng cranks at ffw, di rin umubra, yung may pic na solusyon at kalang sa goma ang da best!
lord vader
PostSubject: Re: FFW problem   Sat Sep 05, 2009 5:47 pm
eto similar
pics from pat`s post
benjo
Bike : Zhi z3r
PostSubject: Re: FFW problem   Sun Sep 06, 2009 6:06 pm
Mismo yan oks ah...
abot ko nalang sayo, patanggal naman...
complikado pala... hehehe...
Tsaka mas oks nga kung katala ang gamit, mas hardcore...
salamat kapatid...
erikjon
Beginner
Beginner
Number of posts : 88
Bike : Old skool
I ride a : Basta...ols skool sya...really old.
Registration date : 2008-12-04
PostSubject: Re: FFW problem   Mon Sep 07, 2009 8:49 am
Hate to say it Benjo pero sabi ng friend ko, because of the leverage a crank exerts on a ffw, if you didn't put any anti-seize copper grease or equivalent, you WILL NOT be able to remove it unless you cut it off.
BUT, i'm sure even though yung mga Signaporeanos can't do it, pilipinos WILL find a way! hahaha!
Good Luck Benjo! Sana yung method ni Sir Oca works!
lord vader
PostSubject: Re: FFW problem   Mon Sep 07, 2009 9:13 am
di kumplikado benjo,simple lang.
yung nut & bolt will serve as lock para kahit anung pihit mo di kakabyos ang ffw tool
basta ganito ang gawin mo pagtuhog, bolt,washer,ffw tool, ffw,cranks,washer, last yung nut.
works very well for me, ganan lagi gawa ko, syonggal agad ang lola
mamaya picture-an ko nga
davidoff
PostSubject: Re: FFW problem   Mon Sep 07, 2009 10:08 am
AMEN to that! cheers cheers cheers
lord vader
PostSubject: Re: FFW problem   Mon Sep 07, 2009 3:35 pm
eto pics ng sa aken, kunwari yung vicegrip ang cranks kasi wala ako sampol cranks.
di gaano mahigpit ang nut at bolt ha, just enough to secure the sprocket tool para di kumabyos
lastly, sa ganitong posisyon, ikalang mu ang dulo ng cranks w/ pedal (vicegrip in this case) sa gulong ng oto, then using a longer tube, ipasok sa katala saka birahin pababa
mahalaga sa gulong ng oto kasi nagpi-flex yun ng konte, di masyado napu-pwersa ang komponents
sana makatulong ito kapatid, lalu na sa ibang nahihirapan magkalas ng FFW
JANG
PostSubject: Re: FFW problem   Mon Sep 07, 2009 9:49 pm
kukunin ko ocs! kaso tagal mo magtxt nun _________... hehehehe!!!
bibisita rin ako dyan, sino sasama!? hehehehe!!!
davidoff
PostSubject: Re: FFW problem   Tue Sep 08, 2009 12:33 am
OT: jang pagpalit mo nang cranks pwede ko mahiram yung 4bolt bash mo,
may nakausap ako na pwede gumawa, ipapagaya ko. ipapakita ko lang sana...
lamat.
JANG
PostSubject: Re: FFW problem   Tue Sep 08, 2009 3:59 am
uki!
PostSubject: Re: FFW problem   Tue Sep 08, 2009 8:32 am
Mahusay yan oca a....
@Benjo gusto ko isa ayos ang bash ko LOL kailangan ko bumili ng chain whip.
JANG
PostSubject: Re: FFW problem   Tue Sep 08, 2009 9:49 pm
mainam yan!
benjo
Bike : Zhi z3r
PostSubject: Re: FFW problem   Tue Sep 08, 2009 10:07 pm
di kaya ng chainwip yan pat...
gawin mu kuha ka ng luma chain, balot mu sa cog, tas ipitin mu ang cog na nakabalot sa chain sa vice tas pihitin mu ang crank arm... kelangan mu pala ng mahaba bakal nakapasok sa arm for leverage... yun lang ang makakatangal jan...
Oca mismo ka!!
Salamat!! coolman
JANG
PostSubject: Re: FFW problem   Wed Sep 09, 2009 3:36 am
pat parang sila cycleops meron nun sinasabi ni benjo kasi nagpagawa ako last time may nakita akong parang vicegrip na na may chain pang tanggal ng cog
PostSubject: Re: FFW problem   Wed Sep 09, 2009 9:50 am
Pucha, hirap nito a, ito ba yun?
o kaya na ng bench vise?
lord vader
PostSubject: Re: FFW problem   Wed Sep 09, 2009 11:28 am
Oca mismo ka!!
Salamat!!
thanks senyo!
benjo di cog ang aalsin ni pat, bash ring ata, kasi umiikot pag hinigpitan, so di nakatapat kung magba-bash man
FFW problem
Page 1 of 2Go to page : 1, 2  Next
» Problem with Power Cord
» How can i fix a priming problem?
» Snapper Transaxle Problem?
» PS3 Master account problem
» SD 2100 switches off by itself... battery problem?
pinoytrials :: Bike Trials :: Bike Trials Talk-
