 Rigid or suspension fork?
Goto page : 1, 2, 3  Next
rolie
Lurker
Lurker
Number of posts: 6
Bike: Stock
I ride a: Stock
Registration date: 2008-06-10
PostSubject: Rigid or suspension fork?   Wed Jul 30, 2008 9:32 am
Newbie here. I am trying to learn some basic trials move. And I am trying to setup my stock bike for it.
Here is my current bike setup.
1. Generic alloy frame, generic suspension fork(travel around 80mm), generic and headset. (bought my cheap bike in cartimar)
http://www.trials-online.com/images/geometry.jpg
(Image courtesy of www.trials-online.com)
I have measured my frame and geometry of frame is exactly the same as in the picture.
2. FSA DH handlebar 710mm wide.
3. Cane Creek Direct Curve Brake Levers
4. Cane Creek Direct Curve 3 Rim Brake
5. Shimano Deore SL-M530 Rapidfire Plus Shifters - 9-Speed (Rear Shifter)
6. RaceFace Ride XC 22t-32-44t. (planning to remove 44t and replace it with a bashguard. Dunno where to buy.)
7. Wheelset - Shimano Deore Hub, 7-speed cassette, rims(don\'t know the brand, but it has a sticker \"Girder XC OCR\")
8. Serfas Gator 2.0\" Tires (Front and Rear)
9. No Front Derailer and Shifter
From what I see in forums and images of a stock trials bike, they are using a rigid fork(except for RL and JLo stock bike). I am planning to buy a new fork.
I am considering Surly 1x1 Rigid fork(1kg,suspension corrected-80mm) and RST GILA Suspension Fork w/ Lockout(2.5kg).
Fork price is almost the same, around Php 3000-3500. No budget for a pricy suspension fork, like Fox, Rockshox, or Marzocchi, which I think weigh less thant the RSTs.
Which fork should I go? I will mostly ride urban, and maybe if I learn jump up to curbs, benches, etc.[left]
Number of posts: 2827
Bike: KOT MS2
I ride a: Stock
Registration date: 2008-02-25
PostSubject: Re: Rigid or suspension fork?   Wed Jul 30, 2008 1:01 pm
Dude biased kami sa forum sa rigid fork hehe.
Ok naman ang build mo pero sooner or later kailangan mo ng fatter tires. I would go for the surly 1x1 rigid fork. Ok sya at 1kg. My rigid fork is around 850grams.
Main reason is to be able to ride smoother at less weight.
Sama ka sa amin sa rides pre.
Number of posts: 2951
Bike: Adamant A2 / GT Chucker
I ride a: Stock
Registration date: 2008-02-26
PostSubject: Re: Rigid or suspension fork?   Wed Jul 30, 2008 1:48 pm
yeah my vote is surely 1x1 also...mas magaan, mas madali hatakin pataas
zteg43
Number of posts: 3064
Bike: echolite 07
I ride a: mod
Registration date: 2008-03-30
PostSubject: Re: Rigid or suspension fork?   Wed Jul 30, 2008 2:52 pm
rigid.Smile
sa umpisa masakit sa braso, but once you get the hang of it, you wont go for a suspension fork anymore.
for starters, rigid would be the best choice. to be able to practice the moves easier. since it wont bob. especially doing an endo move. mas direct ang impact sa arms mo, and trials is about muscle memory, so di confusing, kasi di nagbabago ang height ng fork mo. para rin masanay ka na mag compensate sa pag absorb ng impact, hence, being one with the bike.
isa pa, kung low budget fork mo, mabuti pang wag nalang. di ka rin kasi matutuwa sa results.Smile
View user profile http://www.dyanilaotattoos.multiply.com
joolz
Macho Dancer
Macho Dancer
Number of posts: 612
Bike: wala sa ngayon
I ride a: kalas si jeproxx
PostSubject: Re: Rigid or suspension fork?   Thu Jul 31, 2008 1:06 am
kung ayaw mo muna gumastos kalikutin mo muna ang current fork mo at ilagay sa pinakamatigas na setting na kaya mo using elastomers... tapos igsian mo na rin kumbaga naka compressed siya para matigas tapos at least naka parallel sa ground ang chainstay mo in other words mga zero drop/rise ang BB height mo...
pero kung may pera ka rin lang mag rigid ka na...
pero nakakamiss ang suspension fork shet namimis ko yung fork ko haaaay.... oh well...
sana mag enjoy ka at mahalin mo rin ang trials kagaya namin...
ika nga ng master patrick sama ka sa mga rides para ma hooked ka hehehe...
WTF?! I can't trackstand!?!?!?!
rolie
Lurker
Lurker
Number of posts: 6
Bike: Stock
I ride a: Stock
PostSubject: Re: Rigid or suspension fork?   Thu Jul 31, 2008 7:52 am
Salamat po sa mga reply nyo.
Then I should go for the surly fork.
One of these days makiki-ride ako sa inyo.
Im from Filinvest Cainta. San ba usually ang meeting place nyo?
Bike: KOT MS2
I ride a: Stock
PostSubject: Re: Rigid or suspension fork?   Thu Jul 31, 2008 9:21 am
Basta sa una pre mga aadjust ka pa nyan. Expect mo na sasakit ng konti ang wrists mo at mumurahin mo kami hehe
Ako dati at si Joolz hindi nag adjust dahil sobrang tigas ng suspension fork namin. Nung nag rigid ako wala na. Na-feel ko yun na ang setup ko. Sobrang solid ang pihit ko etc.
zteg43
Bike: echolite 07
I ride a: mod
PostSubject: Re: Rigid or suspension fork?   Thu Jul 31, 2008 2:29 pm
ayus! cainta, malapit sa UP!!! tara!!! hehehe check mo directory. text mo ako ha!!! hehehe
raimun
Number of posts: 341
Bike: Merida AM3000, Merida HFS2000, Merida FLX Team Carbon, Merida TFS900, Merida Mission3000, Echo Pure
I ride a: Echo Pure 04
Registration date: 2008-03-03
PostSubject: Re: Rigid or suspension fork?   Thu Jul 31, 2008 6:36 pm
dud, makinig ka kay pat. mag rigid ka na para masanay yung mga kamay mo kaagad.
joolz
Macho Dancer
Macho Dancer
PostSubject: Re: Rigid or suspension fork?   Mon Aug 04, 2008 10:56 pm
ako sinubukan ko pareho... i tried both sides of the coin, nag suspension at nag rigid para alam ko kung anu ang nawawala sakin hehehe...
I ride a: Stock
PostSubject: Re: Rigid or suspension fork?   Tue Aug 05, 2008 9:47 am
para hindi masyado pressure sa wrist mo, medyo lambutanko ang front tire mo, para mag bounce lang at siya ang kumain ng impact
kam0t3
Sport
Sport
Number of posts: 216
Bike: bente purgada
I ride a: monty 211
Registration date: 2008-03-04
PostSubject: Re: Rigid or suspension fork?   Tue Aug 05, 2008 7:55 pm
lean back lng! hehe..
hindi talaga maiiwasan sumakit ang wrist, kya tangapin na lng ang sakit. mawawala din yan o masasanay ka. hehehe..
tsard - ako hindi pwede malambor ang harap, tutupi ang gulong ko. 221 lng rim ko sa harap. hehhe...
I ride a: Stock
PostSubject: Re: Rigid or suspension fork?   Wed Aug 13, 2008 9:30 am
hahaha XC ka sa harap hehehe..ok yan mas magaan iangat..ingat ka nga lang sa pag wheelswap at iba pang front moves kasi baka bumigay agad hehehe
rolie
Lurker
Lurker
Number of posts: 6
Bike: Stock
I ride a: Stock
PostSubject: Re: Rigid or suspension fork?   Tue Aug 19, 2008 8:45 am
nakabili na ko rigid fork. pero ndi surly, masyado kc maiksi un surly, bumaba un BB nun ni fit.
I bought a fireeye stoker, I think its heavier than the surly 1x1.
yup, for XC nga ata un rims ko. still saving to upgrade to stronger and wider rims.
Pics of my bike:
nakalimutan ko pala i-lower un seatpost bago kinuhanan ng pic. hehehe!
sana matuto na ko!!!
one more question, how do you shorten the length of your chains?
zteg43
Bike: echolite 07
I ride a: mod
PostSubject: Re: Rigid or suspension fork?   Tue Aug 19, 2008 2:03 pm
kailangan mo ng chain cutter tool. kung wala ka, paputol mo sa Local bike shop mo. ano ba plano mo sa chain rings mo? single o 3? kung babawasan mo kasi ang chain, mabuti pang alisin mo na yung biggest chain ring. o kaya naman, single speed mo nalang.
Page 1 of 3Goto page : 1, 2, 3  Next
» I need some front fork bushes..
» K100RS front fork stuck replacing oil seal
» SUSPENSION
» suspension setup help
» Thanks Wayne for the Suspension up grade.
pinoytrials :: Bike Trials :: Beginners Area-
