 Pros Setup
Go to page : Previous  1, 2, 3  Next
shoti
Call Boy
Call Boy
Number of posts : 849
Bike : Drilled Mod
I ride a : Proto Mod
Registration date : 2008-02-26
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 6:28 pm
Nikkocholo---- KMC KOOL CHAIN
Number of posts : 2951
Bike : Adamant A2 / GT Chucker
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 6:30 pm
Thanks shoti
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 8:26 pm
Yan gamit ko sa bike ko Nikkocholo ambigat pero ang tibay hehe
Quote :
- For use with 8 speed gear systems, also works on single speed setups.
- 7.8mm pin width.
- Mushroom head pins to eliminate splayed links.
- 1300kg max. load capacity.
- 302g (full length)
Ito lang mas matibay dyan:
Quote :
Gusset Tank Chain
Description
- Fed up of breaking chains? Then you should be looking at this beast!
- Super Heavy Duty 1/8” chain.
- Pin Length 11.6mm.
- Pin riveting power 300Kg (standard chains are around 150kg, KMC Kool chain is 250kg)
- Tensile strength 1500kg (KMC Kool chain is 1300N).
- Plate width 1.4mm (std chain is 0.8mm, KMC Kool chain is 1.1mm)
- Weight: 550g
benjo
Number of posts : 993
Bike : Zhi z3r
Registration date : 2008-02-29
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 8:32 pm
ako rin yan gamit ko.... bili na!!!!! hehe!!!!!
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 8:36 pm
Oi san meron? magkano?
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 8:42 pm
Kina Norma sa Cartimar P400+ ata pero bili ko dati nyan nasa P300 lang kasi favor lang sa wrench na di ko pwedeng bangitin ang pangalan. Laughing conflict of interest kasi.
Jay18
Call Boy
Call Boy
Number of posts : 846
Bike : Aorta 26"
Registration date : 2008-03-05
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 8:43 pm
pwede rin ba yan sa geared yung likod? kasi 14t,16t & 20t ang gamit ko.
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 9:28 pm
Sinong Norma bro? kasya kaya sa tensioner ko? yung deore rd na sira? Kanina kasing umaga I tried fitting a BMX chain, hindi kasya. Sumasabit pag ikot na..
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 10:18 pm
Bro si Norma yung may ari ng Diacompe, yung bike shoop sa may beat up palengke accessible via the yucky kadiri road. yuuuck.
Not anymore!!! Now they are sosyal na, right beside the likes of Paulinas they are located beside no.13 of the Bikeshop rows in cartimar.
Nikko you can fit a pair of spacer on both sides of the jockey wheels.
shoti
Call Boy
Call Boy
Bike : Drilled Mod
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 10:20 pm
Mas Gusto Ku Kasi Ang Lookzz Ng KMC KOOL CHAIN...
Eto Gamit Na Chain Ng Bmx Friend Ku
Shadow Conspiracy Interlock
INFO:
The Shadow Interlock changed the way chains are viewed. No longer are chains just a way to connect your drive train. The Shadow Interlock gives you adjustability, strength and a more unique look to your ride.
The Interlock has now been on the market for three years and has proven so successful that many chain makers are copying the design. Beware, not all half link chains are made at the same level of quality as that of The Shadow Conspiracy Interlock Chain. Shadow is sure that in this day and age of BMX and track bikes, the Interlock will perform to the level that you demand.
Side view: You can see the slight curve to the plates makes the Interlock Chain fit 9 tooth and higher drivers.
Rollers: The brace helps reduce and / or eliminate cracked rollers. Also the brace rests against the chain pin to help make for a stronger roller and to reduce the roller floating on the pin. All this gives the chain a stronger connection.
Pins: Center punched ‘mushroomed’ pins make for an amazingly strong connection.
SPECS:
-The innovator of the half link chain
-9 tooth and higher compatible
-Weight: 15 oz with 98 links
PostSubject: Re: Pros Setup   Mon Mar 17, 2008 11:31 pm
Ilan ba ang brand ng half link Shoti? Meorn yan dito matibay din daw. P650.
Nga pala Shoti may pads dyan sa GT pang magura di ba? Nakita mo na ba? Ano anong klase/brands/color? May Rock pads ba?
shoti
Call Boy
Call Boy
Bike : Drilled Mod
PostSubject: Re: Pros Setup   Tue Mar 18, 2008 10:21 am
pat========di ku alam ku ilang brand lahat...
pads sa gt... di ku alam kung anung kLase padz yun.... ang kulay ng padz yellow, orange at transparent white.... mahal..... 850 bawat isa....
PostSubject: Re: Pros Setup   Tue Mar 18, 2008 10:31 am
Shoti na inspect mo ba? Alin ang malambot at matigas sa mga pads na yon? Yung malambot kasi pang no grind to light grind at matigas sa harsh grind. Nag grind na kasi ako dahil dumudulas yung pads ko ng konti muntik na ako ulit hehe, bumilog kasi ang pads ko (Magura)
Pwede kaya ipa mail sa post office ng GT Bikes yun? May email address ka ba nila o cell no.?
Kailangan ko na ng pampalit bumibilog ang pads ko kasi, wala pa yung ni order ko na Blueberry, wala pa stock so di pa pinapadala.
ewik
Number of posts : 325
I ride a : Dirt/Street Two50
Registration date : 2008-03-04
PostSubject: Re: Pros Setup   Tue Mar 18, 2008 11:22 am
K710 = (Kool Chain) upto 1,300Kg tensile strength
Z510 = upto 1,200Kg tensile strentgh. light but strong. rare nga lang these days Shocked
shoti
Call Boy
Call Boy
Bike : Drilled Mod
PostSubject: Re: Pros Setup   Tue Mar 18, 2008 1:45 pm
la aku no... nasa ozamiz aku ngayon....
may nakalagay 95 yung pads.... baka 95 durometer nun
PostSubject: Re: Pros Setup   Tue Mar 18, 2008 3:02 pm
Thanks bro.pag napadaan ako Carti, tzek ko
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 8:43 am
Thomas Ohler's New Bike
An Ozony's
Jay18
Call Boy
Call Boy
Bike : Aorta 26"
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 9:43 am
WOW!! ZIADO Black... hehehe...
Pat - tingin mo pwede butasin yung rim ko? yung odessy.. plano ko kasi.. para gumaan yung likod. Habang hahanap pa ko rear hub, pag tripan ko muna yung rim. hehehehe...
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 10:08 am
Pwede kasi one time mo na tirahin habang papalit ka ng hub di ba. Isahang gastos hehe.
Parang bigla ko gusto mag black na bike hehe, hmmmmmmmmmmmmmmmmm esep esep.
Jay18
Call Boy
Call Boy
Bike : Aorta 26"
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 10:25 am
hindi kaya bimigay yun? hindi ko kasi alam kung gano katibay yung rim ko. Very Happy
dapat ata maging smooth ang landing para hindi bimigay agad. hehehe...
ganda ng black noh? repaint repaint... hehehehe...
benjo
Bike : Zhi z3r
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 10:58 am
Ganda rin!!
pero mas gusto ko parin yung dilaw nyang bike... Very Happy
kam0t3
Sport
Sport
Number of posts : 216
Bike : bente purgada
I ride a : monty 211
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 11:00 am
ganda ng stem!
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 11:38 am
Syntace ata yan...pero yung bars iba na.
benjo
Bike : Zhi z3r
PostSubject: Re: Pros Setup   Tue Apr 01, 2008 1:57 pm
Habang tumatagal mo titigan, paganda ng paganda...
PostSubject: Re: Pros Setup   Thu Apr 03, 2008 11:18 pm
Wesley Beleay's OZONYS XR 26
Pros Setup
Page 2 of 3Go to page : Previous  1, 2, 3  Next
» Asian Tour Pros
» waders pros & cons
» Pros and cons of a crossbar
» RZR Radio setup?
» torque converter setup on mud mower
pinoytrials :: Bike Trials :: Bike Trials Talk-
